offset question - Wheel and Tire Forum
offset question
Thursday, September 07, 2006 7:21 PM
2004 cavalier...16 inch stock wheels....stock is 42mm offset....will a 48 offset fit or will it look dumb b/c they will stick out way to much
I AM the man from Nantucket
Re: offset question
Thursday, September 07, 2006 7:23 PM
also im lowered 1.4in on eibach pro kit
Re: offset question
Thursday, September 07, 2006 7:46 PM
Going from a 42mm offset to a 48mm offset will result in the rims and tires moving inward by 6mm, not outward. If you are not changing the wheel width, then the only effect will be that the tires move about 1/4" closer to the body, probably not overly noticeable.
Re: offset question
Friday, September 08, 2006 4:21 AM
the rims are 17x7....i think that the stock chrome wheels on the LS sport are 16x6....
Re: offset question
Friday, September 08, 2006 6:43 AM
So with 17X7 w/ 48 offset versus 16X6 w/ 42 offset, the inner edge of the rim will be 3/4" closer to the body and the outer edge will be 1/4" closer to the fender. Then you may want to consider the difference in tire width, if any. Just add or subtract to each side one-half of the difference. So if you were to go to a 215 width versus the stock 205, you would add 5 mm (3/16") to the inner and outer dimensions.
Re: offset question
Friday, September 08, 2006 8:00 AM
you'll be fine. im running a 18x7.5 w/ a 48mm offset
Re: offset question
Saturday, September 09, 2006 12:32 PM
I just found this page because I'm dealing with offset confusion as well, as I am trying to pick out a set of wheels.
http://www.1010tires.com/WheelOffsetCalculator.asp
Re: offset question
Thursday, September 14, 2006 9:45 AM
You probably want a lower offset like 40, 38, or 35... I'm running 18x8.5 +35 with no problems, other than I had to roll my fenders, and I'll probably be pulling my front fenders slightly.
+48... those will be sunk.
Re: offset question
Thursday, September 14, 2006 10:59 AM
20Rob05 wrote:You probably want a lower offset like 40, 38, or 35... I'm running 18x8.5 +35 with no problems, other than I had to roll my fenders, and I'll probably be pulling my front fenders slightly.
too bad you have an 03 or else you could get the toyota fenders that are slightly wider
Re: offset question
Thursday, September 14, 2006 12:27 PM
How much is slightly wider?
Aren't the fenders the same? Fitment-wise, not width, I mean. The only difference is the small filler piece that takes the place of the cornering lens of the 02 and back headlights, and that filler piece is on the bumper, not the fender.
Re: offset question
Thursday, September 14, 2006 12:59 PM
lol yea your right. my fault, ive been working all day so my brain is like fried from doing stupid work but yes the fenders are the same from 95-05. how much wider i dont know but if you look up some toyota cavalier fender threads you might be able to find out. i know that they are noticable wide though.
Re: offset question
Thursday, September 14, 2006 6:56 PM
Sweet. Maybe I will pick up a pair instead of cutting my fenders and getting blister flares.
