i want a z24 but have the reasoing of y spend money if ya dont have to
so im wonderin if i got a regular 99 cavalier with a 2.2 and a 5 speed could i swap a 2.4 ld9 with a 5spd with out a problem and if anyone has done it just a few helpful hints
just tryin to get a z24 for as chap as possible
so hopefully i can find a z24 that has a blown motor and i can get motor and trannys cheap so
If your not installing the motor and trans..then your still not getting anything cheap. You can pick up a z24 3gen..say 1996-7 for 4G's CND in perfectly good condition. If you do find a z24 of those years for 1000 with blown motor, trans, suspension work needed. By the time you finish repairing everything, your money into the car is gonna pass the amount of 4G's easily.
If you can't dish out $4,000 right now, save up and buy one later on. Not only that but insurance is gonna kill you. When i first got my 3rd gen at 20 years old..i was paying 3,500 a year...and that was with a clean record
Its not as bad as people made it out to be, but yeah it can be expensive if you dont have the time or patience to wait for parts to come up cheap. When I swapped over on my old 4dr it took over a year for the right deal to pop up, a 99 2.4 & trans with 20k miles for $800. But if you can't find usable wiring anywhere, it cost over $1k from GM, upper mount is like 100. Then exhaust, pcm, coolant tank, etc. Easist swap out there.
