Hi Guys,
    It's been a long time since I've had to ask The GURU's a question.
Have a '96 Pontiac Sunfire. Back in 2007-8, I clipped the Blue Wire under the Dash Pad to kill the DRL's. It worked and has been working until now.
I installed a set of LED Headlight Bulbs (with a CAN-BUS) in it. The light doesn't flash until I turn the Headlight on for the first time. After that, it flashes continuously until I turn the headlights ON or turn the Car off.
I SEARCHED J-Body looking for a answer. I did unplug the relay in front of the radiator, and jumpered "30" to "87A" even. Same results still.
The BCM has to be looking for a signal from somewhere to say "Stop Flashing"...
Any and all help is appreciated...
As Always, Thanks Again !!!
