HeadLight Conversion Kit - Exterior Forum
Monday, March 02, 2015 11:12 PM
Welcome to my Headlight conversion thread
This is more my adventures and questions regarding re-wiring my Cavalier's Headlights and install a set I found nearby.
I have IPCW Halo Projector style headlights. I'm in the process of installing them but had a few questions I'm curious of
First of all, The low beams and High beams are easy, They just go right in, even the Turn signals are no problem for me.
Anyone else who has done this conversion, the side LED's and the halo's, do you prefer to attach these to your parking lights circuits or do you prefer to attach them to your Daytime Running lights circuits?
Also if I use the Parking Lights circuit, do you think disabling the daytime running lights would look better as well?
"I like to burn money in piles too" -Brian
Re: HeadLight Conversion Kit
Wednesday, March 11, 2015 4:31 AM
If you have the schematic and know what you're doing, I would make the halos and LEDs your DRL. However, there will be a bit of cutting into the harness at the underhood fuse/relay box, and if you don't do it right, you could cause yourself some headaches.
Wednesday, March 11, 2015 9:26 AM
I was running my Halos as DRL's for a while and I liked it. To do it you'll need to pick up a a pair of load resistors to connect in parallel to the halos, and it is easiest to get running by adding an extra relay tripping the DRL's.
Wednesday, March 11, 2015 11:49 AM
I wired mine into the parking lights so that I could turn them on or off when I wanted. Just splice the wires for the side LEDs and halos into the marker light that goes into the side of the headlight housing.
