My 05 Cav-fire is lacking the Sunfire exterior door panel pieces and I cannot find a part number anywhere for them. What are they even supposed to be called?
thanks,
-Josh
can't tell ya what they are called but they are all the same 95-05 so just run to your local yard.
and dont forget the clips that they attatch with. if you're getting the rocker panels too, they have a metal bracing rivited to the rocker panel that you will need to grab as well.
Thanks for the input guys. I have the rocker/ skirt pieces, but I'm not sure if the bracing is there. Now that I know that 95-05 is the same, I'll look @ pull-a-part.
Gary Frank wrote:they are all the same 95-05 so just run to your local yard. Josh Meyers wrote:Thanks for the input guys. I have the rocker/ skirt pieces, but I'm not sure if the bracing is there. Now that I know that 95-05 is the same, I'll look @ pull-a-part.
They're not the same looks-wise. The 1995-2002 side skirts are smooth. The 2003-2005 side skirts have the "Sunfire" indentation in them under the rear side windows...
1995-2002 Sunfire GT
2003-2005 Sunfire
Thanks for the pics, J2Envy... I must have the pre-03 skirts because mine are smooth. It looks liek the caps are the same for both, though.
