Ive searched and read alot about the HIDs for cavalier headlights, I have the HID's for m fogs already, but Ive read you need projectors to do the headlights. Do you really have too? I do know the lighting is illegal...I also believe it seems from reading the other forums on this topic that somethin with the cone thing for the bulb.cant remember the name rightt ow so it attracts cops even more... Can someone clear this up for me pleaseee.
Thanks alot in advance!
If there is no projector you will blind on coming traffic.
159$ projector headlights on amazon.
i have a ddm 10000K set in my 03 never hear any complaints bout em and i have stock headlights you dont need projectors they just make em look better
Justin Mozingo wrote:i have a ddm 10000K set in my 03 never hear any complaints bout em and i have stock headlights you dont need projectors they just make em look better
You sir are an idiot. Op get projectors. Search any other hid thread here and you will see. Projectors are a must.
Because of how low my car is, it had no problems with HIDs. I also had mine pointed down, and tested with friends. But i will agree, if you can, wait out the install and buy projectors because it's the best way. I reverted back to halogens for now though because my relay harness died and DDM is not wanting to warrant the product after 2 days of actual usage. F*ck DDM Tuning.
Btw, i had 35W, 5k 9007 hi/low setup with relay harness option. My car is also lowered 2" or more all around and unless I was going up hill, it wasnt in anyones eyes.
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
I have a car with factory xenon headlights and no projectors.  They blind no one. They are made for Hids
Hids are not "illegal", its the colors that can be illegal.
To the op, there are threads on this all over the place on here. You stated you read that you need projectors, guess what, you answered your own question. Gm never made housings for Hids for the js. So you have 2 choices, retrofit or buy projector lights. Remember though, not all projector housings are made for hids.
Certain non projector headlights support HIDs well. Im running 5000k in my 00-02s and never have been high beamed. Not sure if my theory is valid but it could be due to the fact that the bottom reflector is painted black to explain the minimized glare. Personally I dont think anything over 6000k is worth the money. My HIDs work well on all types of roads whether its asphalt, concrete, wet, or dry. J(see pic below) Just thought I should throw that in there in case you ask about color temperatures.
I got a 6k kit, looks just like the one above. Projectors on the cavalier, stock housings on the bravada. Never been flashed.
ddm can suck a fat one... my relay harness took a dump and their "HID Module" needed all the pins tweaked to keep a good continuity...
maybe you got a bad kit ive had mine in for 2 years never a problem and projectors arent needed they just look better so you sir are an idiot
