It says they come with hid in the description?
No, they are just replacement headlight assemblies that use regular 9007 bulbs, no HID's included.
"United by Individuality"
"If life is a joke, why aren't we laughing?"
"Normality depends on one's perception of reality."
http://www.cardomain.com/ride/3820803
I posted the wrong link lol 1 sec
I'd pass on it.  It's pretty much the same as the one you posted previously, it just has a DDM Tuning like HID kit, not a true HID retrofit type kit.  And also, it's kind of a waste to get 10000K HIDs in my opinion.
Though for a brand new set of headlights and all parts, $100ish isnt bad shipped. Then thats dirt cheap for the HID setup, assuming it comes with the harness and everything you need.
But your headlight housing (the black plastic that covers the bulb in the back) WILL have to be modified to fit the HID bulbs. You will need to drill holes/cutouts inorder for the bulbs to fit AND have that piece twist back on. You will also want to look into sealing your hole back up somehow or moisture/condensation will get into your headlight housing since its no longer sealed. I know first hand. i just installed a DDM Tuning set for my 9007 hi/low setup, and that part was a semi-PITA.
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
DDM.
That is all. My kits work perfect from them.
www.hidxenonlights.com. I got my set from here...$79.99 for the 6000K and $35 for the relay kit and it works great!
Mike wrote:DDM.
So if I get the HI/Low kit do I still need to disable my DRLs? if so wheres the sticky? thanks
And do I get 35 or 55 watt?
What all do I order from the drop down selection?
I was thinking about 8000k as well.
10,000k would be worthless
Spencer wrote:10,000k would be worthless
I think so too, I have blue xenon bulbs i cant see anything when it rains I hate it.
I have 6k 35w kits and it is just right. Not too much color, and plenty of light. Go higher in color and you will lose visibility.
anne shaffer wrote:www.hidxenonlights.com. I got my set from here...$79.99 for the 6000K and $35 for the relay kit and it works great!
Wow. That is expensive. DDM is almost half that, On both items. With a lifetime warranty.
So I need to disable my drls right? And I need the by pass for 15.00?
