OK so before some one goes postal I've read the Sticky, I have searched many different ways and still do not understand......
Ok So I have a 98 Cavalier Sedan and I am swapping over to the 03-05 LS Sport body panels.
So far I have the...
03-05 LS Sport Rear bumper
03-05 Impact Absorber
03-05 Brackets ( Thanks J-Hand)
What else do I need? Does the rear metal impact bar stay or get removed? How does the foam impact absorber get attached to the car. I am just trying to give as much information to S&R performance when I drop off the brackets and the foam absorber.
Sorry this has been talked about a million times but I have not seen a step by step process....
You have all you need, the metal impact bar does not change. I forget how the foam bar attaches, it's been a while since I pulled my rear bumper
The foam is held on the impact bar by a few plastic clips. They are the ones you pull out the center and then they pop out if that makes sence. They are the same as the ones on the plastic cover on top of the rad but bigger.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
Anybody have a GM part number for these clips? I want to go scoop some before I go drop off the impact absorber and the rear brackets.
Is this what your talking about?
Ebay
thats what hes talking about
