Im wondering if its possible to put hid' s in my fogs of my ls bumper.
If so what is the bulb size and will the stock wiring handle them?
Thanks.
880 series bulbs and get the wiring harness.. 20 bucks for piece of mind
Daniel Thissen wrote:880 series bulbs and get the wiring harness.. 20 bucks for piece of mind
Do I have to be concerned about them getting to hot and melting the housings??
the bulbs melting the housing?
Yes.... I swear I read it happened on here...
Melted the lens and such...
alot of people were upgrading the 880 bulbs with a higher wattage bulb and melting the housing. However HIDs do run a little cooler then halogen, I also ran HIDs in my fogs with no issues other then blinding everyone infront of me. So i highly discourage it. Thats why i bought Blazer projectors and mounted them in my fogs to use HIDs so they are not blinding everyone. Its stupidity to run HIDs in stock halogen housings that were not made for HIDs
I did see your post with the fogs and projectors.... But not sure how you went about it.
Stephen (manta z) wrote:alot of people were upgrading the 880 bulbs with a higher wattage bulb and melting the housing. However HIDs do run a little cooler then halogen, I also ran HIDs in my fogs with no issues other then blinding everyone infront of me. So i highly discourage it. Thats why i bought Blazer projectors and mounted them in my fogs to use HIDs so they are not blinding everyone. Its stupidity to run HIDs in stock halogen housings that were not made for HIDs
care to link the post... and i saw some hid with 880 hid bulbs on ebay
link
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
putting the projectors in the fogs is really not hard at all.. there is only one way it can go in so you buy the projectors, open up a big hole in the back for them and silicone them in. i had to modify the metal mounting bracket a bit too but again was nothing major just takes some time. I suggest before glueing them in to mount them on the car and turn them on and make sure the projector is not tilted up in the housing other wise you will be blinding everyone that way too lol
