Hi, i was wondering if you can purchase a Cavalier Lip those on the 2002 Cavalier ls sport....and will it fit with slight modification on a stock bumber..
02' ls sport coupe lip
thank you,
larry
Also What about the Whole Body Kit...Rear Bumper...Side Skirts.
Rear.....
Side Skirts...
They should fit if you can find them. Good luck.
if you can fond them, then yes. The side skirts are easy to find. They are on all 1995-2002 z24 models. The front and rear lips from the 2002 fit all 2000-2002 bumpers, you just have to cut the holes in the bumper to mount them. As far as I know you can buy the lip from GM and even the plastic tabs that mount the bumper, but it might be expensive.
the fourth word is suppose to be FIND and the side skirts are on all 1995-2002 COUPES only for clarification....
There are a few options.
If you have any U Pull It junkyards near you, the side skirts are a dime a dozen. All you have to do for installation is to mark and drill holes down your rockers for the skirt clips to pop into. I tend to see quite a few rear lips in junkyards too, the front lip may be harder to find though.
Keep an eye on the classfieds here on the org, I always see rear lips floating around there, and some front lips here and there. I got my front lip from another org member in the classifieds.
You can check car-part.com as well, you can search local wreckers in your area, and I've definitely seen of the components of the lss kit on there.
Anyone ever try a 02 or earlier lip on a 03
Modding my j since I found the org
It's been done a few times before.  Strat81 was running it before he got his new rear lip off me.
What about the front I've been looking for a rk sports but I loove the ww type front lip
