I have a damaged Xtreme Tuner Front bumper.  I assume it can be easily fixed by any competent body shop.  I'm curious what would be used, and how easy it is to fix?  It is made of ABS plastic.  There are pics of it in the NorthEast Local forum.
oooh trust me.. if you only knew the amount of work i've put into a xtreme front, that crack is nothing. 3M Automix 08235(50 second work time) or 08237(3 minute work time) is what I would use(use it all the time at work so its readily available to me)
Evercoat makes a good plastic repair as well, and then most people know of Lord Fusor products as well.
Awesome, thanks for the info!  I'm really really glad to hear it's an easy fix.
Now I can't decide if I want to keep it or not.
I'm partial to the Norton Speed grip products (same idea as the 3m automix/fuzor/etc). I use their urethane base panel bond to seal up cracks, then use Evercoat Poly-flex to it out.
Well nobody wants it, so looks like I'll be keeping it.
Thanks for the info guys.  I assume any good body shop will use the above specified products?
Easy fix, My IF had a 2-3 inch crack in the bottom lip and I fixed it with the 3M stuff.
