Was curious if the 2dr side mirrors from the cars were the same??? ive never even thought to ask until now so dont burn me too bad lol...
all 2 door mirrors are interchangable, and all 4 door mirrors are interchangable, but you can not put a 4 door mirror on a 2 door car.
Much appreciated, thank u
also, convertable mirrors will not fit on a coupe or sedan.
cannon fodder wrote:also, convertable mirrors will not fit on a coupe or sedan.
Just curious - why not? I thought the vert doors were the same as the coupe minus the window frame / b-pillar section. I know for a fact the panel that covers the mirror on the inside (as well as the door panel itself) is the same. My door panels are from a vert and they fit no problem.
Road To Change wrote:cannon fodder wrote:also, convertable mirrors will not fit on a coupe or sedan.
no...no u don't know that for a fact, because the inside mirror cover is different to lol....your right on the door panels being the same tho
Gary Frank wrote:Road To Change wrote:cannon fodder wrote:also, convertable mirrors will not fit on a coupe or sedan.
Maybe I got lucky then, because my passenger side cover is off a vert.
interior wise mostly everything is the same. but the mirrors themselves are different shaped then coupes. coupe doors were cut to be vert doors, but the doors also received bracing.
Road To Change wrote:Gary Frank wrote:Road To Change wrote:cannon fodder wrote:also, convertable mirrors will not fit on a coupe or sedan.
i didn't say it doesn't fit, i said they are different....vary different....a vert one is over a inch thick, reg. one is only like a 1/4.....that being said just because it came from a vert doesn't mean it was its original
  if the vert was hear i'd take a photo to show u, night and day difference.
Gary Frank wrote:Road To Change wrote:Gary Frank wrote:Road To Change wrote:cannon fodder wrote:also, convertable mirrors will not fit on a coupe or sedan.
I will take your word for that. I did notice my passenger one was thicker material, but I figured that was just because it doesn't have the little adjustment thingy on it.
