I am looking to pick up a 03 LS rear for my cav.   I want to fill in the  "Chevrolet" in the rear bumper but know better then to use just regular filler.
What products..ie fusor, 3m...etc should I be using to do the filling in of this?  Also if there are any kinds that doesn't involve buying the expensive gun that would rock!
I also have started...or shall I say am finishing modding my import fighter front to my 02 headlights...what should I be using for the molding / filling / bonding on that.
Ive read that poly-flex by Evercoat is a good filler for the finishing stages..truth?
thanks for the help..
fusor would be your best bet for that and drill a ton of pin holes in it too.
BuiltNBoosted wrote:fusor would be your best bet for that and drill a ton of pin holes in it too.
What are the pin holes for?
*I know very little about body work*
The idea behind the pinholes is to let the fusor or like product to seep through and help it bond.  But im not a fan of drilling the holes since it leaves the product completely open to water and such to get under it, via the holes.
I know basic bodywork concepts and such...but haven't really worked with the newer adhesives/fillers.
once you drill the holes... the fusor will come through the holes and seal it....
Ah, Okay. Cool. Thank you.
