So I've located bcm, the middle plug, and on that middle plug i've located the only dark blue wire.
After cutting it I have to attach an extension wire to the 2 inch blue wire that is still connected  to the socket/plug that plugs into the bcm. Right?
Then the other end of the blue wire (which is no longer connected to the bcm because I cut it) I just tape off with black tape. Right?
Yep, you just ground the end that's attached to the plug.
