I tried searching but couldnt come up with any answers. I just two weeks ago installed my new HID kit from DDM. Everything worked fine for the past two weeks then all of a sudden my pass side HID went out. When I turn the lights on the driver side fires right up and works fine but the pass side just flicks on for a split second. It just flashes and then goes out. I can turn the lights on and off as many times as I want and it wont fix the problem. Does this sound like a bad ballast? Or just a bad connection. During the install I had trouble getting the pass side to light up but after I messed around with the connections it worked fine. Any help or insight would be awesome. Im hoping its not the ballast. I dont want to be without a headlight while I send it back to ddm.
Thanks
try switching the bulbs around.  If the passenger side lights up and not the driver side then its the ballast.
If i switch the bulbs around thats not gonna tell me anything about the ballast. I would have to switch the ballasts wouldnt I?
So I decided to start swaping stuff around to eliminate some possibilities. And to my surprise after switching around the bulbs they now work fine. Must have been just a loose connection or something.
