I just did a head light mod, so i'd have angel eyes. I would like to have them come on when i turn the car on, and thought that swtiching the DRL to the angel eyes would be perfect? Any suggestions on how i can do this?
Easier way, wire the halos to an ignition on source and done.
I <3 JGM
 I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
In Loving Memory of Phil Martin December 14 2005
I had actually tried wiring it into an accessory wire in the cabin, and with my stereo and everything i was drawing to much power.  The angel eyes' wouldn't come on nor my amp. Do you know of any other hot wire that i could use and locate easily?
 thanks
Use an add-a-fuse and use the wiper fuse.
I <3 JGM
Or wire the radio accessory wire to a relay and make yourself a switched power rail for future expansion.
Or actually buy a service-manual that has the factory wiring-diagram in it & learn which wires are what running to-&-from the DRL relay. Then pull you under-hood fuse-box (Perhaps the only way!), disconnect or bypass the circuit part leading to the high-beams & run it to the Angel-eyes "on" point (I've never seen them, so I don't know if there's a relay involved with them or not). Project done!
Go beyond the "bolt-on".
