I have a few spots that a little rustly.
Just wondering whats the right way of getting rid of them.
sand prime, prime, paint. clear coat? Not to sure about the clear coating. How to I make sure it blends in correctly?
cut it out, weld in new patches.
cut out bend metal. weld in like so.
do some bondo work.....
sand that.....do more bondo work....
and then get it all straight and shoot the whole car in primer. =]
im 17 and i did this all myself so if you cant do it then you are illiterate lol just messin but i did this all myself and FINALLY in the process of getting the car painted for all of you who were keeping up on my car updates a while back.
1999 2.4L w/ nitrous
its just 3 spots that are not that bad. the metal belowthe rust is still thick  so i don't need to add metal to it. Its very minor at this point.
so sand it down to the bare metal
do i clean it with anything at this point?
then prime it, once, twice? (anything special or just any primer?)
Get the color code which I've gotten. spray the dried primer.
Now the clear coat part. Not to sure about it. Will any clear coat do? I've never worked with clear coating. This is the part that i'm worried about.
I don't want the repair noticable after i'm done. Any tips are appreciated.
as far as painting it, just take it to an auto body place after you do the rust repair and prime it. they can usually blend it pretty well for a decent price. if you want a flawless looking repair, thats the way id go.
youv'e been told what you need to do. to actually repair it you have to cut it out and weld new metal in. that's it.
if you catch it when it's very, very minimal you can sand it down, prime it, paint it, clear it. but this is only a temporary fix in my opinion. the only real way to get rid of it is to actually cut it out.
I can't just fix each spot. I would have to repaint the whole bumper right?
The cars dirty in these picture by the way.
blucavvy wrote:youv'e been told what you need to do. to actually repair it you have to cut it out and weld new metal in. that's it.
If its surface rust, it can be taken off and prepped. It is rediculous to patch an area of surface rust. There is surface rust on most sheet metal that you will patch with. You are just opening up the possibility of  getting rust on the back if you don't get everything completely covered.
