well if you are going to use those clear lenses......you NEED projectors.....period.
The Sunfires use that scatter lens to put the light in the right place, without it, the light will not go where it needs to be......unless you have something....like a projector to direct it.
The kit Eternal is linking you to is hands down the most affordable projector option on the market today. You cant beat the value, and the ones I get come with the full HID kit, and warranty.
Installed in the Sunfires, they look like this:
Definitely the best bang for the buck. your only other option is to throw in some OEM projectors, make shrouds, and buy an HID kit. But you will pay more.
Actually eternal your thread was most of my motivation. I mean i have seen them on many different cars but your thread was the closest thing to haveing EVERYTHING on it that i would want in a thread. The only thing i wished it had was prices, options, and what exactly you ended up using.
And John, I know i need projectors, that is the point of this thread. From reading what i wrote you can tell i did my research.
ANYWAYS.... so you think i should go with the HID kite and the projector kit i have listed? It will only cost about 150 more dollars to finish it if i went with this.... that sounds sexy to me. lawl
John Benham wrote:well if you are going to use those clear lenses......you NEED projectors.....period.
Exactly
GTmatters wrote:Actually eternal your thread was most of my motivation. I mean i have seen them on many different cars but your thread was the closest thing to haveing EVERYTHING on it that i would want in a thread. The only thing i wished it had was prices, options, and what exactly you ended up using.
Thanks man. Yeah, Id def go the route that your looking at. Believe me, its worth it. If you have any specific questions about how I went about things in my thread, PM me.
Sounds great, thanks a lot man.
Just a heads up, the advice that eternal gives im sure will be good, but remember he has his reflector housing inside a larger assembly, your reflector housing is also the headlight housing, therefore things that Eternal does not have to worry about, you may have to waterproof, for example, the connection for the CCFL angel eye/high beam wires (the small wiring harness). You would have to put a piece of shrink wrap over the connection that is inside Eternals headlights.
BTW, do you have any shots of the back of your headlights Eternal, I would like to see how you routed your bulb and angel eye wiring.
Yeah i have heard from more than just him that it isnt too big of a process.. but we will see.
John Benham wrote:Just a heads up, the advice that eternal gives im sure will be good, but remember he has his reflector housing inside a larger assembly, your reflector housing is also the headlight housing, therefore things that Eternal does not have to worry about, you may have to waterproof, for example, the connection for the CCFL angel eye/high beam wires (the small wiring harness). You would have to put a piece of shrink wrap over the connection that is inside Eternals headlights.
Right now the back is open. I dont have the cover back on yet.
Edited 1 time(s). Last edited Monday, July 20, 2009 9:06 PM
