OK, since no one replied to me on the sticky, I am only posting outside the sticky because I need immediate attention to the problem.  Anyway, I performed the 03-05 DRL disable on my car.  Now the driver side headlight is dimmer and both high and low beam.  I know it isn't the bulb because I followed up with a set of Silverstars today.  I did use the dark blue wire on the plug side and I grounded to the exact same location under the dash.  Is there something I need to do to get my brightness back.  I thought about running the wire into an on/off/on rocker switch.  I figured I would run from the plug to what should be power in on the switch, one side power out to the ground, and the other power out to the original wire.  This would give me the option to turn them off during the day and then flip the switch so the wire works again when I flip the headlights on.  Would this fix the problem or is there a simple one time fix aside from undoing the disable?
If it can't drag, it ain't low enough!
my 98 the drives side was ridiculously dimmer then the other, replaced the fuse and problem was solved.
