Hey everyone, I was hoping someone could help me.
My 2001 cavalier's right front turn signal flashes quickly all of a sudden does that mean I need a new bulb? could it be burnt out?
Anser to your question ..... Yes and Yes
it could be ether or ...
all its telling u is that the signal going to the bulb is not 100
so ya ... bulb blown or something worse like a socket or harness ....
let us kno how it goes
change the bulb for a start. Then if it continues its somethin else more expensive. More often than not its a bulb. Both times I've had this problem it was a bulb.
Joe Pacilli wrote:Hey everyone, I was hoping someone could help me.
your right rear turn signal is burnt out change it.
azncav 2,4 2,2 wrote:Joe Pacilli wrote:Hey everyone, I was hoping someone could help me.
exactly what i was gonna say
so, x2
do a test on it first don't just go buy a bulb... turn the blinker on with the ignition on and go look at it.... Check front and back it could be either one! After you realize your bulb is crap go buy a new one and fix it! You're car will be fixed in 3 minutes...
P.S. Mine blink fast all the time on both sides but it's because I run LED's in my blinkers and they use alot less power so the car thinks they're burnt out... I have to get a load resistor to fix the issue but I kind of like them blinking all crazy fast! I run clear reflectors with blue LED's and it looks awesome!
Pilz-E wrote:I still dream of the day when I can do a rear-engine, rear drive V12 in my sunflower.
unattainable wrote:do a test on it first don't just go buy a bulb... turn the blinker on with the ignition on and go look at it.... Check front and back it could be either one! After you realize your bulb is crap go buy a new one and fix it! You're car will be fixed in 3 minutes...
got any pictures of that?
he already stated that his FRONT blinker was blinking fast.
