Hey,
I am sorry if this has been asked before somewhere, but would really appreciate someones help.
I have had the on-going HID flickering or one light not coming on issue. So now I am about to purchase the HID relay wire connector and run it straight from the battery to fix the issue as many people mention.
The question I had is, how do I go about setting this up (simple or hard?), and how does it integrate with the HID plug and play kit.
I understand and know how to wire up the plug and play HID kit, but how do I incorporate the HID relay wiring, and where does it all connect.?
Any information, pictures of wiring up the system, or direction would be greatly appreciated.
Thanks.
This would be a 9007 connection for an 05 Cavalier.
I THINK I pretty much understand the setup now by the pictures and diagrams..but I am lost on one thing.
Any wire harness I see has a "single female plug to plug into your factory harness", WHERE exactly am I plugging this? I was thinking there would be 2, one for left side, and one for the right.
But where exaclty does the plug into the factory harness plug, since its a single connection.
OR, will a 9007 setup for the 05 cavalier have 2 plugs?
PLS HELP!!
My harness is the same way. You take the female plug and plug it into you drivers side factory harness. The other side does not need to be plugged in. Then you connect the ballasts to the other two plugs that are in you relayed harness. When you turn on the lights the drivers side factory harness sends a signal to the relayed harness to turn on both of the lights.
Custom Made 04 CF HID Projectors
