Hood pins - Exterior Forum
Hood pins
Thursday, November 16, 2006 1:24 PM
Well I just got my SS hood and my latch does not line up. So im just going to use hood pins. My question is does anyone have a picture of where they mounted there hood pins? Im not sure if i want them far away or close together? also any tips on drilling threw fiber glass would help. Thanks.
Re: Hood pins
Thursday, November 16, 2006 1:29 PM
Not sure on placement of the pins, but I know one thing for sure. When you go to drill the holes, make sure you have enough blue painters tape, or green 3m masking tape covering the hood where you are going to drill....this will save you lots of frustration and more painting later. Sorry I couldnt help with the placement.
Re: Hood pins
Thursday, November 16, 2006 1:30 PM
most people put them where the rubber bumo stops are
and its "through"
and i would find out why the latch doesnt line up
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
Re: Hood pins
Thursday, November 16, 2006 1:37 PM
i dont see why the latch doesnt match up but ok. anyway open your hood and there are 4 bump stops up front. one by each fender and 2 in the middle by the headlights. use which ever 2 you want.
Re: Hood pins
Thursday, November 16, 2006 2:49 PM
I don't know why the latch will not go down? it looks lined up but will not push down? I tried pushing and slaming it but it wont work? Oh well hod pins will be fine. thanks
Re: Hood pins
Thursday, November 16, 2006 3:44 PM
Yeah, how do you put hood pins where the black bumperstops are?
Not being a smart ass; i just dont know; i have a cf hood and have ran it on my car for 6 months in the spring and summer without hood pins, but people tell me i really should have pins in her as well, and i would feel more comfortable.
But i would reccomend getting your oem latch checked out and having your hood held down by the latch and the pins; just the pins is kind of unsafe.
Good luck man.
When drilling through cf, same thing use tape over the exterior of the hood and underside?
98 j-body sedan
Re: Hood pins
Friday, November 17, 2006 3:48 PM
yeah all sum a hole has to do is walk by your car n pul lthe pins out n u be drivin down the road n have a hood in your windshield get the latch fixed and use the hood pins together that way u won't have to worrie about replacing a windshield
Re: Hood pins
Saturday, November 18, 2006 5:58 AM
^^ hes correct.. Hood pins arent really made to use by themselves.. people do.. but there more used for anchor points to help the stock latch distribute the force put on the latch into 2 more points.. You really want to figure out whats wrong with ur latch.. Where did u get the hood from? U might just need to play with the latch a lil.. move it slightly to the side a little bit or something
Re: Hood pins
Saturday, November 18, 2006 1:04 PM
are thefre two different style hood pins?
like i heard there was a kind to stay away from that can rust and you cant get your hood open, anyone hear of this?
98 j-body sedan
Re: Hood pins
Sunday, November 19, 2006 12:04 AM
Your right about somebody pulling out the pins! I just finished putting an 89 Z24 hood on my 94 convertible. I figured easier just installing the hood pins than changing latches. Got a couple of small locks & put clear vinyl over the chrome rings........no problems yet! Marty
Re: Hood pins
Monday, November 20, 2006 12:31 PM
yeah pins are definately extra security but the latch really is the central mount and anchor point for the hood
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
Re: Hood pins
Monday, November 20, 2006 12:58 PM
Manta Z(The Primered One) wrote:^^ hes correct.. Hood pins arent really made to use by themselves.. people do.. but there more used for anchor points to help the stock latch distribute the force put on the latch into 2 more points.. You really want to figure out whats wrong with ur latch.. Where did u get the hood from? U might just need to play with the latch a lil.. move it slightly to the side a little bit or something
I used hood pins for like 9 months on my car after the hood flew up. Then I picked up another hood for $50 and ditched the pins!
Re: Hood pins
Monday, November 20, 2006 1:29 PM
terry denomme wrote:Yeah, how do you put hood pins where the black bumperstops are?
Good luck man.
you removed the bumpstop and put the pin in there. the pins come w/ washers and nuts. put a nut and washer on and then put the pin through the hole then add the other washer and nut then you can adjust the height of the pin and tighten it where you need to.
Re: Hood pins
Monday, November 20, 2006 2:21 PM
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]
Good luck man.
Thanks, so what happens with the bumper stops?
And are you useing the inner bumper stops sp that the pins would be in the middle of the hood, or the outer ones so that the pins would be abover the headlights?
98 j-body sedan
Re: Hood pins
Monday, November 20, 2006 3:58 PM
use whichever ones you want
Re: Hood pins
Monday, November 20, 2006 10:52 PM
I mounted the hood pins beside the bumpstop.........I was in a hurry to try the rag top out, as i never owned one in my 40 years of driving!!!!!!!!!! I love the car. This friend Dave is bugging me to put a turbo on it but i dont know. He said he could make me one up cheap. I,m restoring it this winter & tryin not to do anything stupid.
Re: Hood pins
Wednesday, November 22, 2006 9:11 PM
Hey man, this might help....I typed it up for a friend. Check it out: http://www.cardomain.com/ride/767263/5
It's a write-up with pictures of what I did. Enjoy!
Click on my sig to check out my CarDomain site. Enjoy!
Re: Hood pins
Wednesday, November 22, 2006 11:52 PM
Hey thanks!!!!!!!!!!! i,m really impressed with your CarDomain site!!!!!!!!!!! Being an old fart (59) i,m really impressed with all of you folks tryin to help each other out! I,m crazy over cavs and the wife thinks ive lost it!!!!!!!!!!!!lol Marty
Re: Hood pins
Tuesday, November 28, 2006 10:30 PM
hey thank you veyr much, i try and keep it up to date with every mod that i do.
Re: Hood pins
Wednesday, November 29, 2006 1:13 AM
Thanks guys for all the advice.. But I was going to do the pins so i took out the rubber stops, but they screw in to a square with no possibly way to put the nut on under it? So I used some WD-40 on my latch and it worked:-)
