I want to move my gas cap to the trunk opening.  My questions are what type of piping shoudl I used to move the gas line up there?  Would fiberglass work to get the hole in there and perfectly rounded or what should I use?
-->Michael Ferrari
Just be carefull and not spill gas into your trunk.  That would sux.
Fact 1:
This post may contain misspellings, grammatical errors, disorganized sentence
structure, or may entirely lack a coherent theme.These elements are natural
to my process of writing, and will only add to the overall beauty of the post.
Fact 2:
“Facts are meaningless. You could use facts to prove anything that’s even remotely
true.
i think they sell certain tubes for gas.  check an auto store.
I had to get marine tubing cause everything else was pre cut, I still haven't done it yet but I have some instructions and a list of things you'll need if you want it
UNDER CONSTRUCTION!!!
Check out my site
http://members.cardomain.com/lil_z
tried searching for something and found this..anyone know of another link that still WORKS ABOUT THIS?  I plan to move mine soon but need more info on it~
thanks
aplus' link still works for me.
Do you think I could just take a gas filler neck off another cav to extend mine.  Or should I just use hose, to extend it.  I was going to order this off
ebay.  But I don't know if that whats I need
^^^as long as you have a way to bend the metal tubing, that would definately work!
i ended up cutting my stocker in the wheel well, then getting gas filler tubing to run from the filler neck in the trunk down to the stock piping under the pass. wheel well. just requires cutting a hole in the well to fit the tubing.
If you have CF engine bay pieces, SELL THEM TO ME!
Built Not Bought
I guess I'll try that, whats the best to seal off the connections?
i used metal clamps like you would use on an intake....but smaller obviously. you can get them at any autozone, advanced auto, etc.
Built Not Bought
does any one know who put thier gas filler behind the passenger tail light. i remember seeing it i think the car was red and the light swung out on a bracket
i did a half way decent write up on this a while back
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
