i know its dumbbut how
2001 2 door five speed 122k.
custom steering linkage pop
2000 s10 (THE WORKS)
remove the rad cover and its 2 13mm bolts on each headlight
the corners need to come out first but they just kunda slide foreward and pop out. i found it was easier to get the corners out after i unbolted the headlamp. but they do clip together and the corners gotta come out first or you cant angle the headlight to get it out. youll know what i mean when you do it. also im assuming your talking about the 2001. good luck
the bolts are 13mm or 1/2...same diff
but use a flat head or cat-claw to pull up the center of the things that hold the radiator cover in
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
