Ok, i used the search function and didnt get much help. All the links in the previous forums are dead. Now here is my question, i ordered these
Toyo Tails but it did not come with any wiring harness nor instructions. My question is, if i go to the wrecker, and pick up some other cavalier tailight sockets, with those bulb sockets fit into the amber signals? because i have no harness for these i would need some info on how to wire them up, since i would literally have to get another set of sockets and wire them to those white wires or whatever in the steering column. So if anyone has any links which work or ideas please let me know. thanks
if you live in Japan, thats the only way your going to find a wiring harness in a junkyard....other than that, you'll have to find another set that comes with them...you could order them from GM, but i heard that its a lil pricey..you could splice your turn signal and make a custom socket but thats outta my league...good luck though...
where there's a will, there's a way....
ahhh your the one that got those!! They went from like 80 bucks to like 115 in seriously 30 seconds. I tried bidding on them but you guys are too quick for me
Yes u should be able to wire in new pigtails.. go to junkyard and clip some.. I do beleive they convert to single filament bulbs for the turnsignals tho.. since there just turnsignals.. anyway u can use the pigtails.. just find out which wire lights up the brighter filament and use that.. hell this is what i thought off.. cut the wire that triggers the turnsignals on the taillights.. then just run that wire to ur other pigtail.. that should make it work just like the toyos i would think.. Next spring ill be doing some similar wiring with a couple different bulbs mounted in taillights..so lemme know if that works out for ya..
yea hopefully it will, does anyone have a link to lenkos instructions which works? diagrams etc?
better
install link with pics.
my carDomain updated 11/13/06
I've got premium. Yes I do. I've got premium. How 'bout you?
grab them from the wrecker 2 sets of tail light pigtails, they'll be a bitch to install
i paid $90 USD for mine, with every harness
1998 Chevrolet Cavalier
5-spd
the sockets from a 95-99 american should in theory work
I AM the man from Nantucket
Just a question, what do these toyota tails look like; and why does everyone want a set so bad, because they are from japan, that is pretty cool; what are so different about them, the orange in them?
98 j-body sedan
look at my very first post for a pic....
