Just did a retro on my 03 cavalier with Valeo D1s projectors and i was wondering something......I did the DRL mod but im still concerned with the headlights flashing when you lock/unlock your car with keyless entry. Will this harm the bulbs in anyway?? And if it does how can i disable the flashing???
Will put up some pics of my retro soon. Thanks
definately interested in seeing the retro!! as for the bulbs, i dont have personal experience, but i dont think it will harm the bulbs.. if it is a concern, there should be a simple wire clip to disable the flashing lights when arming the alarm.
i dont know for a fact if they will certainly get harmed, but i would never chance it. if there is a way to prevent it from happening, i would suggest doing it. you dont want those ballasts and bulbs turning on/off so fast. but like i said, i dont know for a fact. i will find out for you though. give me about an hour.....
oh, i want to see some cut off line pix!!!!!!!!!!!!
Valeos are sooooo nice. i have a couple of sets here, but ill be carrying valeo bi-xenon (hi beam & low beam) projectors and HID kits very soon!
-Www.IznTrbl.Com-
i know what he means with the lights flashing when u lock and unlock the car , when i got my 03 i it had PIAA bulbs in it and they seemed fine now that i have the Silvania Sliverstars it might be a diff story. only time will tell if its harmfull to the lights
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
ok, sorry it took so long. here is what my buddy said:
it is bad for both the ballasts and the HID bulbs to flash on and off. it will shorten the life of the igniter and the HID bulb, so tell your friend that if theres a way to disable the lights flashing when the keyless entry button is pushed, they should do it. if they cant figure it out, the dealership shouldnt have a problem doing it.
i hope this helps you out kevin. good luck with everything, and get some pix up on P&M when you have a chance. id love to see them!
-Www.IznTrbl.Com-
you can talk ot you local dealer or anyone with a Tec2, they can disbale the flash and or the honk with a Tec2
Awsome guys, this has been a real help. For right now im just going to live without my alarm and just lock and unlock my car with my key
until i can get it disabled. Reguarding the retro, it still needs some work. I went out to the car this morning and my driver side headlight was all fogged up......i probably could have done a better job sealing it. As for the cutoff lines, they look pretty good but their not perfect. I am getting a decent amount of blue/purple cutoff tho. I did the washer mod to 1 projector, but i couldnt get any more color out of the other one. Anyway, i will put up some pics later today......
Put some pics up on P&M, check um out!
They can do it at the dealer. Before I knew this I just pulled out my drl relay and the lights didnt flash with the alarm. Only drawback is you service light will come on until you put the relay back in.
Custom Made 04 CF HID Projectors
Do you know how much the dealer would charged to do it???
Does anyone have a link to some 03 and up cavalier wiring diagrams?? Thanks
