how can i fix this my new headlights are already fogged up pretty bad
take them off
open the headlights up
clean the lense and let everything dry completely
put back together with clear silicone
it probably wasnt sealed right the first time, hence why its fogging
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]take them off
exactly
SO EVERYTHING!
do i just bake them for like what 2 mins
I know you probably wouldnt wanna do it but... when my clear corner fogged up someone told me to drill a small hole in it and it will clear up and after a day or so it did and hasnt fogged since.
Reality is an illusion caused by lack of drugs
wickedscavy wrote:do i just bake them for like what 2 mins
you can heat them up just a little bit if you want or you can just get a razor blade and cut the glue and use a hair dryer to soften the glue so you can pull it apart. if you bake them, you might ruin them by leaving them in too long or having it to high. i suggest using a hair dryer and a razor
Tj Peters wrote:I know you probably wouldnt wanna do it but... when my clear corner fogged up someone told me to drill a small hole in it and it will clear up and after a day or so it did and hasnt fogged since.
yea but then water can get in. when you drill the hole it lets whatever moisture thats in there escape from that hole but it also lets things in.
