Does anyone know what the bulb and harness is that fits into the bumper lights? I went to Toyota to get the supra harnesses awhile back, but they where $80 and I don't remember what fits.
Jason
USACi =>146.9db
its the 97 supra lights that fit in there and talk to lenko he will tell you how to use your stock harness to get it to work
i just dremeled out the opening in the supra light so that the stock bulb and socket fit nicely
you can buy the socket from toyota and jus splice into your turn signal wires and wire it up that way...thas what i did and it works like a beaut...
I think the driver's side harness for the Supra was $80, and the passenger's side was like $20. So I just bought two passenger harnesses & spliced into my turn signal wires. It took some trial & error to get them to work the way I wanted to.......I didn't want them constantly on when my headlights are on & I wanted both bulbs to blink at the same time instead of in sequence. It's been a while since I did the install, but I think I only spliced in one of the wires on the harness, and it made both bulbs blink together so I didn't even use the 2nd wire.
Chris99z...........do you know what size bulbs go in them?
Jason
USACi =>146.9db
Each light takes 2 bulbs(one small & one bigger) for a total of 4 bulbs. I'm about 99.9% sure that the small bulb is a 194. I'm not sure what # the larger bulb is though. I know when I bought my Supra bumper lights on eBay last year, they came with the bulbs. Click
here for a link to an eBay auction that pictures the bulbs so maybe you can figure out the # of the larger bulb.
