I've got a '99 Cav Z24, and I like the look of the front end of the '03 Cav. Is it possible to swap the front end of an '03 onto my '99 Z24??
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Well, I found this info:
03-05 Cavalier
- 03-05 Cavalier Headlights(with plastic mount, its what bolts down the headlight)
- 03-05 Front Bumper
- 03-05 Fenders(00-02 can be used, IF you remove the corner bracket if you have a 00-02, also 95-99 can be used IF and only you cut off the bracket that holds the 95-99 turn signals on)
- 2 x 9007 High/Low Beam Bulbs
- 2 x 3157 Turn signal Bulbs(any 3rd Gen has these for turn signals so not necessary unless you need new bulbs, you can use what came with your car)
- 2 x 194 Bulbs for turn signals(any 3rd Gen(except 00-02 Cavaliers) have these for turn signals so not necessary unless you need new bulbs, you can use what came with your car)
- From the donor car's wiring harness, or two 9007 headlights sockets(unless you have a 95-02 Sunfire, or 00-02 Cavalier, these already use this bulb for headlights) and two 194 corner light sockets(Only needed if you have a 00-02 Cavalier, all the rest have this bulb already wired on your side markers or part of your turn signals)
Is that all correct?? I can use my 95-99 fenders AND hood??
1997 GMC Sierra
2005 Honda TRX450R
