Whats different about 03 sunfire sides opposed to all pre 2k2 gt's? And I believe you'd be using a urethane filler to do what u asked, like fusor or similar product, not 100% tho/
You mean like shave them where they wont be there? or just paint inside them? I got a good idea and product to use that i PMd u..
got an up dated pic of my filler plate. that i filled in
i think it looks good.
ok my advice is not use "bondo" on plastic its not flexable and it wont last i dont care what any one says not goin to last
if you are inexperienced with this type of work then do not attempt to do it your self
1st you need to determine what type of plastic you are working with , iam guessing this is either tpo or tpe, and in this case the plastic needs to be promoted with a plastic adhesion promoter
2nd lightly grind the area, and kinda bevel the edges, i personally would try make a piece that fits in the pontiac head to cover the hole, i would use panel bond yes panel bond it sticks and is flexable i do it all day long at work and have been for yr`s
3rd d.a. the area with 80 apply the promoter let it sit for 10 min`s i personally recomend 3m`s automix system they bought out duramix and 3m`s product in bar none the best around, then apply the plastic repair product
finish it off with 180 then 240, tpo tpe teo plastic when working with it swells allot so ya have to keep working it down with a finer grit paper
that`s what i would i have done it before and works out great but please don`t put bondo on plastic, it`s just so wrong
can i haz bondo
^^^ pretty much what he said.
Bondo + urethane/plastic = won't last long... because bondo/filler doesn't really have any flex to it.
It could be filled with a urethane based compound, it's worth talking to the shop about
not so sure about just shaving the pontiac off the front i think it would look so much better if you mold the filler panel into the bumper heres my quick chop of it
In Loving Memory of Phil Martin December 14 2005
i dont see any difference in the sides , other than the sunfre in them
