I just bought a plug and play(9007)for my cavi and when i plug everything in, no lights turn on? Is there any wiring i forgetting to do?
wanna tell us if ur using a relay or anything
Prolly should have posted this in exterior, but, did you make sure all the connections are secure?
Reverse the positive and the negative. I had this problem when I had the 9007 hid setup in my cavy .
Custom Made 04 CF HID Projectors
thanks alot man thats the problem!!!! positive and neg were reversed!!!
Glad I could help. Our cavys have a grounded headlight system. So when you try to install a kit you have to reverse the wires in order to get it to light up.
got any pictures of the set-up?
what brand did you do with?
are you using projectors?
