I got a set of one piece dual halo projector headlights from Speedfantasy, the look is awsome, lighting is good, fitting is ok, just one of the six leds is failing anybody knows how to disarm the headlight, do I have to take off the front clear lens loosening the sort of clamps and will I loose the water tight seal. Have to make it right since they are new I donīt want to mess them up.
have you contacted the place you bought them from?
if not, call them up, tell the the item is defective and ask them about sending you a replacement item!
if they are brand new, why fix it your self? they should be under manufacturer defect warenty!
Kardain wrote:Tonite on Fox:
When X's attack
You are right of course, but it is not practical since the headlights came from California ( The store where I ordered them do not provide any instructions or tech advice) and I am in Caracas (Venezuela) the led bulb is about $3 and I donīt think it is fried because if I move it from behind it goes on, it is probably a faulty contact needing some cleaning or straightening the little wire for the positive or negative so it gets a good electrical contact. Thing is how to reach them.
Thanks.
hey luis. can you take a picture of the back of the headlight? i believe you can pull each one of those out. if you do pull it out or take everything apart and pull it out, take a picture of it for me. i have some of those "turn signal" led harnesses sitting here. ill send them to you. you will have plenty exta of those leds then.
you can send the pix to me via email if you'd like: Joshua@IznTrbl.Com.
-Www.IznTrbl.Com-
