Ok so I searched and didn't find an answer. I need to adjust the gap by the door on my passenger side fender because it sticks out a bit further the the door in the middle, and it really annoys me. In the pic you can see how the fender almost looks wider then the door, how would i bring the fender in so that this gap isn't so noticable.
Look by the sunfire badge
SUPERFASSSSTZ, T.Ocav soon wrote:wow thats a really nice ride man it looks sooooooo clean.
Thanks , tho it doesn't exactly look the same right now (I got sideskirts, there in the car in that pic). And Shifted thanks for the reply I'll look at that bolt when I go to work on the car next.
Shifted wrote:There's a bolt inside the door or two right around that area in the fender that attach to the body. Loosen them up, position the fender, and tighten them down.
What he said ^ but looks like you will only need one screw to adjust it.
Do not loose it that much.. about 1/4" at clock wise or so. So that way u can push it in to where you want it to be then re-open the door and re-tight the screw.
Simple fix!
a new look coming in summer 2006
^ yeah what he said
Simple 2 minute fix.
Looks good.
