the passenger is different from the driver different colored wires. i recently did the conversion and i switched them not knowing they were different from each other try to switch the harnessess
That don't make much since. Being as they are Universal Harness's
why are you capping off one wire?
There do that for wiring.. except since u got universal harness just match uphighs and lows like in the pics.. check your fuses to see if that fixes ur dim problem.. if not disable your drls.. CRJ just had a post on his last week which the suggestions on what to do also applies to you.. I dont know who is saying to cap off wires but i did mine just like above and have had no problems with mine.. works wonderfully.. althought my DRLs were already disabled before i did it..
oh im sorry misunderstood i guess. i got mine from a junk yar for like $10. do you have a pic of the universal wire
btw i must add.. i do always recommend just goin to junkyard and clipping off the pigtails there.. usally cheaper/free and u know they work.. odds are they might be a better quality then the 8dollar ones from part stores..
i capped mine off now to mention it i didnt say to do that though. i do know this is funny before i did the conversion my drl stopped working and now with the new heads i have drls explain that lol
i think the fuse's were fine. I checked them and still good.
So I'll attempt a DRL disable tomorrow.
I read the How To and it says BCM... Is that right on the driver side fender wall? I think it has a sticker that says TCS or something to that nature... It didn't say BCM.
And that was the diargram I originially used... There were a few cap off methods when I searched for the how-to
do u have a BCM? i beleive 99- cavs all u have to do is cut one wire.. i know on my 96 thats all i did.. search for a post lenko did on a easier drl disable for 95-99.. just take off ur dash cover and there is a wire u just cut and tape both ends so they dont touch anything and spark
OK, so I did disable the DRLS (thank god i read all the responces) and still have the same problem.
Did you know the car will not stay running with the main guage cluster harness disconnected? LOL. Went to start it, it cranked, turned over, then died. lol.
Anyways, talking to Troll, we've discovered what may be my problem.... I think I may have the passenger side wired wrong. But would that effect both sides? I think my grounds need to be swaped on the passenger side.
Also, I have the one stupid dim headlight, I keep hearing it may be a fuse... What fuse would that be? I glanced over them all and it looked good, but I should probably check them again.
Stenger-
Both me and MantaZ have ours wired the exact same way according to the diagram above. The only problem i had was with my DRL's when turning on they were blowing my driver side fuse, i cut the 1 wire and problem was taken care of. No more DRL's and no flashing light side effect, you must have something wired wrong.
I disabled the DRL's, and replaced the fuse... So the dim light problem's solved.
HOWEVER I still have no lows. Im going to attempt to play with the passenger side light tomorrow, and see if my negs are backwards.
glad u got most of the probs fixed
def check ur wiring for the lows.. Now it could also just be the pigtails also.. but def go over ur wiring..
also have ryan help you.. hes done it so he should be able to help you out. basically u just gotta make sure the harness isnt upside down or sumthing when u wire it..since u got the universals
Btw hope to meet you and ryan saturday at HIN
Uggg... lets not talk about shows i've planned to go to in the last 2 weeks. lol
Summer Showoff - Had to bail on that one because of my girlfriends medical problems
HIN Indy- Yeap. Can't go to that one 'cause were promissed her cousin we'd go to her birthday part in Cynthania Ky that weekend, before I knew about HIN.
GMSCB- Who knows. lol.
k i've had the same problem, the drivers fuse keeps blowing after i replace it. all the wiring is right me and my dad checked it over tonz. The real problem is my car needs to be safetied before i can register it. and if i cut the drl wire. it wont pass, so am i screwed or what?
Disabling your DRLs makes it unsafe and wont let u pass inspection..i dont understand it..
