ok i have been thinking about putting a tow hook on my car.but where should i mount it any suggestions.any body have one on there car?
so no chains get hooked to my car if it needs to be towed and i like the way it looks
I'm with halfj99 but to each his own. You can pretty much put the hook anywhere, but if you want it functional you should attach it to the bumper so it has plenty of strength.
dont we have a toe hook???? i know when i towed mine home when i blew the motor i jsut used that hook by the lower engine mount???
Thanx Charles
i have a 95 z and no not that I've seen
Chris warble wrote:so no chains get hooked to my car if it needs to be towed and i like the way it looks
if your car is towed right there is no way chains will touch you car only T-hooks. besides othert than towing it yourself, this hook would not be used
(ex flatbed tow truck driver- 2 years)
you put the smoke down that long??? ^^ I don't see a toe (or tow) hook either.
j
Crystal(CrazyCavGirl) OR Jacob wrote:you put the smoke down that long??? ^^ I don't see a toe (or tow) hook either.
j
nope sure didn't
small tow company was friends with the owner.
sweet. but that still doesn't make me see a tow hook. or toe hook... or tow loop.
j
well i was also considering putting a tow hook, i wouldnt want them using the lower one near the underdrive pulley. i dont want the body kit to crack if they should ever pull the car. so far i want to put a tow hook to mount to the front support beam and i might have to make a small slit on the body kit(TRD Gravana kit) the best example of what it might look like is from the Top secret Rsx race car.
ilike te tow hook idea...looks hawt on hondas, i bet its the same on the cavis, they will look awesome
