dose any one have luminics yellow bulbs if so can you post a pic? i have nokya yellow ones but there not that bright are the luminics better?
From what I have seen, none of them are bright unless you go hid. I am going to paint mine yellow like others have done. I think that looks better than a yellow bulb.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Fire Fighter wrote:From what I have seen, none of them are bright unless you go hid. I am going to paint mine yellow like others have done. I think that looks better than a yellow bulb.
do they make 881's in hids? if so were?
What forum is the yellow painted lens in...?
I know they make the hid fogs, I am not sure of what part #'s tho. I think the guys name is blackwidow on the org, he has them. I have seen a couple others as well.
Zspot Zedden wrote:What forum is the yellow painted lens in...?
A bunch have people on here have done this as well. Search around and you will find some pics. You can get it here
http://store.artcity.com/kry-9024.html
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
how can this work i looked up my old bulbs and the ones i just got the spec's on both i found
Luminics:
Bulb Type: 881
Sold As: Twin Pack [Pair]
Wattage [draw]: 27
Wattage [output]: 100
Color: JDM Yellow
Color Temp: 2500K
Warranty: 90 Days
Luminics JDM Yellow series halogens were designed to provide superior visibility in inclement weather and provide a stylish yellow output that is sure to turn heads. Traditionally used primarily in foglight applications, Luminics JDM Yellow have become increasingly popular as an alternative to traditional white headlights. Available in all popular bulb applications, including 800 series bulbs - give your vehicle a fresh new style with a set of Luminics JDM Yellows.
NOKYA's:
Bulb Type: 881
Wattage [draw]: 27
Wattage [output]: 27
Color: Hyper Yellow
Color Temp: 2500K
Warranty: Yes
Upgrade your stock headlight bulbs with NOKYA's newest Hyper Yellow Pro-Halogens. The bright yellow JDM styling provides optimum visibility, and a great look for your car.
How can the output wattage of the luminics put out 100watts and nokya's only put out 27 WTF...
I have the luminics bulbs for my fogs. They are pretty bright. What I think is that the Luminics output is combined. Its like my PIAA Bulbs, regualar h11 but put out the light of 100w bulbs. Also I think the Nokya's are painted, the Luminics are yellow glass. I personally don't like Nokya bulbs, they are mainly for color, not light.
a color temp of only 2500k that sucks, mine burn at 8500k (much brighter)
the k rating changes the color as well... just remember that. so in this case the 2500k would be MUCH more yellow
Capt. Cavalier wrote:a color temp of only 2500k that sucks, mine burn at 8500k (much brighter)
I bet the are not any brighter unless they are HID's. They are just a different color.
As far as the 27 watts vs 100 watts, the output shouldn't be much different if they have the same k rating. I never understood why companies do that. If you got some fogs that put out 100 watts you would melt the front half of the car and burn up the harness.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
