i'm thinking about doing a swap on my z24. the problem is I have molded side skirts. Is it possible to do a swap without having to cut the side skirts?
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
you gonna have to cut them to get the fenders off no other way
In Loving Memory of Phil Martin December 14 2005
^^yep....youre gonna need sunfire fenders...
@!#$, ok thanks fellas
k, i can deal with cutting the side skirts. anyone got a wiring diagram for the headlight swap?
search, this is posted all the time
i have searched. can't seem to find what i need. maybe im using the right keywords. I'll continue to search, but if anyone post it,pm, or email a link that would be great
i too have been looking for it, finding out what the part number for the headlight wiring, and where it attatches is very greatful.
thanx
2004 Nissan Maxima SE w/ Elite Pkg
2005 Infiniti G35 Coupe w/ Sport Pkg
i found it! in this post, there is no mention of a part number for the headlight harness, but it does till you here to disconnect it.
click here
to find the part number go to gmpartsdirect.com i think you can find it there. i'll look, i may need it too
or you could cut the fender, and weld on the sunfire one... above the wheel well...
www.DomesticTuners.com 'The Place To Tune Your Domestic'
COGcaviZ24 a.k.a. Andy Lee wrote:k, i can deal with cutting the side skirts. anyone got a wiring diagram for the headlight swap?
It depends on what year front you are wanting to put on. If you put the 03+ sunfire front on you will not need to change the harness.
Also as you stated you can just unplug it from under the battery or some where like that I believe???
-Brandon
the coma. wrote:or you could cut the fender, and weld on the sunfire one... above the wheel well...
yea, that sounds like could be done(and i'd like be able to do that) but our fenders are WAY too thin. they will worp(sp)
redecocav wrote:It depends on what year front you are wanting to put on. If you put the 03+ sunfire front on you will not need to change the harness.
im not paying of a new front clip from a 03+ and unless someone volinteers their 03+ or if i find one in a junkyard(i dont that will happen), i dont thank im gonna go with a 03+.
i searched, i can get a 95+ front for about $150 give or take. but i've also asked in the southeast region if any sunfires wanna swap. if that goes down than it wont cost me a dime
^^^^ya, the 03 and up fires are a 2 bulb setup like your cav, so there would be no wiring involved.
but since you want the 95-02, you'll have to do some wiring since that is a 1 bulb setup. ill find the diagrams
ps - you should do custom projectors with the 2 bulbs incorporated so there would be no wiring issues
thanks bro, the custom projects sound good. i'll keep that in mind
ok, im getting 2 differant answer about the wiring. can i or can i not just swap the harnesses???
I want to say yes, but then again Im not %100 sure.
-Brandon
that's help LOL
