im looking to see if anyone on here has a wiring diagram for the toyota cavalier mirrors. i did a search and came with nothing.....any help????
See that first post at the top of the page, titled EXTERIOR FAQ:
PLEASE READ ME FIRST. yea, thats all you would have had to do. right on the first page...
I just now noticed I completely left out mirrors.
Mirrors
Like taillights, there are many different styles of mirrors available for the jbodies.
IMPORTANT. 2 door and 4 doors have different style mirros.
Types of mirrors:
Bomex
Toyota
M3 style by APC. These come with and without a LED turn signal.
There is also the rksport carbon fiber mirrors.
carcustoms.net has a collection of most of the mirrors.
Car Customs
Toyota mirrors are hard to find. Your best bet would be to try ebay. "Why are Toyota mirrors so popular?" There are those cavalier owners who strive to have a complete toyota cavalier. Also, the mirrors are different than the M3 style which is worn out. The mirrors are a task to be installed, but I happened to find a post with great detail.
Author: Orange Z24
Date: 08-01-03 07:24 PM
Ok today is a great day for all you Toyota Cavalier, mirror owners. I have made directions to wire up the mirrors. Yes, you will be able to fold them by a push of a button or your remote keyless entry that is if you want to go the extra step. These directions are if you have power mirrors already. If not you are going to need a lot of wire. You should have the connectors, the relay box (black box), and the switch for the Toyota Cavalier. If not contact, the people you got them from if you cannot get them from them contact www.street-line.net to get these parts.
If your mirrors are off Ebay, you probable did not get the wire harness. That is why I am taking the time to write this for you people. Ok now that we have gotten that out of the way, here we go and bear with me first time doing this.
First things first do not connect the wires permantly until the end.
Tools required
1. Wire strippers, at least one good pair
2. Test light or voltmeter. You want to make sure your grabbing the right wires right.
3. Soldering iron and some solder. If you are and anal person
4. Butt connectors for 14 gauge wire
5. 14 gauge wire, in a couple different colors. You want to wire the other mirrors right. A 50ft roll is good and plenty (NO LESS).
6. Heat shrink or electrical tape for your connections
7. Eye connectors for the relay ground.
STEP ONE
Ok take apart your doors if you cannot do this, then smack your self in the head and sell your mirrors. After your door is apart, unbolt your old mirrors and cut the wires to the mirror. Now mount your mirrors if you were lucky and got coupe mirrors you bastard. If you got sedan mirrors break out the saw zaw you’re going need to make them fit. On the other hand, you can have a body man fit them to your car. Either way make sure you have access to the mirror wires.
You should have the wire connector for the power door lock, the stock mirror switch and Toyota mirror wires hanging there. Cut your stock mirror switch off, right before the connector. Peel back the factory electrical tape and separate the wires. Stock wires on the switch should be orange, black, red, blue, white, and green.
Now let’s look at the Toyota switch and connector for the mirrors.
It should have 8 wires on the connector! If not you may have got, a different year switch and connector then me. It should have these color wires on it.
Top
White Yellow
Black/White Red/White
Brown/White
Green
Black Yellow
Now look at the stock wires you just cut. The Toyota mirror switch and the stock switch have the same color wires for the left mirror .If you want to test it, connect the following wires together temporarily. White, the yellow right next to it and the green to the wires you just cut, this is the control the left mirror. To power the switch connect the orange and black to the bottom black and yellow wires. It should now work and you can control the mirror, if not your switch is either set on the right side or it doesn’t work right. Get a new switch
STEP TWO
Ok mounting the switch. Pick a spot and make sure you can reach it with the wires you will be using. I put mine in the door next to the power door lock.
Now that you picked a spot blah, blah, blah. Look at your relay. It should have eleven wires.
BLUE/BLACK PINK/BLACK
TOP GREY/BLACK RED/BLACK
OF -> ORANGE BLACK
RELAY YELLOW/BLACK
GREEN/BLACK BROWN/BLACK
ORANGE/BLACK WHITE/BLACK
Ok find a place to mount the relay and make sure you can reach it with the wires.
STEP THREE
Here is the hard part. Left mirror white yellow wires right next to each other on the switch to same color wires on left mirror. Right mirror is the red/white, and brown/white wires same colors of the right mirror.
The green wire goes to both left and right mirrors. You need to connect the blue/white wire from the right mirror to the green wire on the left mirror and then connect them to the green wire on the switch. Do not permanently connect and of the wires yet unless you are positive you got the colors right. you can temporarily connect the power (yellow) and ground (black) to test it again to make sure the mirrors themselves are working.
Relay wiring. Pink/black, red/black, brown/black, and white/black go to the left mirror. Match color to color. Same with the right blue/black, orange/black, green/black, and grey/black same as left match color to color. Now your almost done.
The power wires are yellow on the switch and orange on the relay. The ground is black on both. Remember the yellow and black on the bottom of the switch are the power and ground.
By now you should have 2 wires left the yellow black on the relay and the black white on the switch. Put them together.
Test. They should fold if not you @!#$ up that’s why I said not to connect the wires permanitly yet. See now you can go back and fix them.
STEP FOUR
EXTRA STEP
If you want to be slick you can hook the black white wire from the switch to the power door lock blue wire. When you lock the doors the mirrors will fold in by them selves but you will need to open them by the switch when you get in the car. It looks cool. If you hit the lock button they fold hit it again they open.
Well there you go
Have fun
SO EVERYTHING!
