Have any of you guys (with a late model cavalier, ie ecotec) "cooked" your headlights? I'm kind of wary about doing it because it just seems kind of.....risky, but if it really works, then im willing to do it. I know how to do it and i know that all i need is clear silicone to seal it back up, but how long and at what heat do you "cook" them at? Also, could the heat of the engine damage any part of the headlight?
i made a mistake, i meant to say "heat of the oven, not heat of the engine." sorry about that.
pull the bulbs out. 350 deg. about 5 mins. heres mine.
IZN TRBL,
Do you have the clear lenses for 03-05 Cavaliers, its the turn signal on the side?
anyone paint the 00-02 headlight housing??
if so what did you use, how's u do it once u got em open
i have black corners and i was thinkin bout doin the headlights as well
LiquidFireCavy (mdk) wrote:anyone paint the 00-02 headlight housing??
heres one that did his
http://www.cardomain.com/ride/382143
but dont paint the whole inside of the housing, or your lights wont be very bright. they need to reflect off the back of the housing
Fred Ohlson "The people that devised this cruel attempt
at acceptance and fame burn in there honda civics"
Heat gun works well too.
Eazy716 (Slamtastic) wrote:LiquidFireCavy (mdk) wrote:anyone paint the 00-02 headlight housing??
yea i kno not the paint the inner silver, but what did he use to do the outside, if you know, shuld i just use fusion?? or is there sumthin better
^^im not positive what product would work best, but i would assume any spray can would work fine. just make sure when you reseal it, it is sealed good. you dont want water and precip. getting in there. thats no fun
I just used a high heat flat black on mine.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
