Have an '02 Caviler. as stock as it gets... Need to adjust the headlight aim and dont know where the adjustments are
Thanks
Bill Ellis
2002 Cavalier 2.2L OHV Sedan (AUG 2001)
2004 Vibe AWD Shadow (May 2004)
the 2 star shaped knobs coming out of the rad cover above the headlights. turn those to adjust. one is left right, and one is up down.
what tool/bit do i need to turn those knobs?
Bill Ellis
Steve (CanadianJ) wrote:the 2 star shaped knobs coming out of the rad cover above the headlights. turn those to adjust. one is left right, and one is up down.
I'm interested to hear about what you're talking about. I was going to say un-bolt the headlight, adjust where you want it, and re-bolt.
Words that you can't use in modding: Finished, Perfect, Cheap.
Ok the screws need a T-15 torx bit!!
the inner adjustment is for left-right!
the outter adjustment is for up-down!
Bill Ellis
hmmmm IZN TRBL....quick acces to headlights in your room...planning a new headlight mod????
the screw are broken on mine is there anyway to aim the light without those ?
On cavys with the 2 bulbs in the housing, are both of those screws for the low beam? I hope so...
IZN TRBL wrote:Machzel08 wrote:hmmmm IZN TRBL....quick acces to headlights in your room...planning a new headlight mod????
he he.
i got dibs on your old ones
not for me silly. i make them almost everyday. ive got a ton of these lights all over my shed. 03+ cavies coming soon.
i cant wait till im done.
-Www.IznTrbl.Com-
i stripped mine using some torx that obviously wasnt right you can also use some socket i dont know the exact size but it works
