will
these fit on an 04 sunfire? I have the ones that come witht he BMX kit for the sunfire but I like these better. Thanks for the help.
They should fit, if they are for a 2 door. I know i can put fire skirts on my cav as long as they are for a 2 door...
2004 Turbo cavalier 11PSI and blown!
now why would you go and buy those when they're pretty much the exact same thing?
because they don't go as far up the side as the ones for the sunfire....plus I want to take off the door filler pieces also.
They will fit but you're going to have to fill in all the holes when you remove the stock sides and door skins. They're held on with plastic plugs through holes in the door, fender, and quarter panel.
i knew that it had clips that were holding it on..a pain but i will take them off and weld/fill the holes....the whole car is being repainted anyways (Laser Blue from 05 equinox).....thanks for the help guys
