Pretty soon I will be changing the rear of my car (tail lights). I was wandering though.. I do not want to have a bezzel thing there (however you spell it ). I want it to look like the older model cav's in the back.. so my question is. Would it be better to just get a new trunk lid (what year? is it 200-2002?) or just get some body filler or w/e and fill in that part where the bezzel would go? Thanks.
-bizzle
I would just fill it in, sand it, and prime..then paint
"J-body.org is just like a oil change, You have to watch every thread you see!"
^^ yeah thats probably cheaper anyways! thanks
-bizzle
Yeah thats what i want to do to mine one day....
 Just do it right ....You're Welcome!
yeah ill deffinitely be sure i get it right! but i wont be doing it until i get a body kit because im tihnking about getting a custom paint job and i want it all done at the same time pretty much if i can
-bizzle
trunk lids from 95-02 are all the same.......  cavalier anyways..... 2 and 4 door.  You'd spend less on picking up one the same color as your car, then filling and painting your stock one.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
^^^ thank you for the info.. very useful
-bizzle
man i see so many ppl on this site take what they think is the cheap and easy way around stuff. First off if you fill that with any... any body filler, it will more that likely crack out. Big spots of body filler will crack i promise. Body filler is meant for minor dings, scrapes etc...
Also the just go to a junk yard and pick up the older style deck lid.... sand it then primer and paint. In the long run its safer and more cost effecient. If the putty cracks you would have painted that lid and then you would prolly go buy an older style and then have to paint it.... screw the body filler. Im done with my long post .............
When i get a new trunk lid.. will i need the bracket things too or just the lid? Thanks
-bizzle
just the lid, the hinges should be the same.
^^ Thank you cannon fodder
-bizzle
