OK, im thinking about gettin lambo doors but my sideskirts are molded in. so if i get the molding broken off do you think i should get new side skirts or just remold the old ones or is there a way to install them with out breaking the mold and removeing my fenders...
See the molding
http://img37.exs.cx/img37/2828/dacopy0wr.jpg
WWW.sinisterambitions.com
break the mold...and also break the spoiler while your at it
They can be installed without removing the fenders... It's not easy but I know of AT LEAST two people who have done it...
Make that 3............
i installed my lambos without removing the molded skirts.....its by no means easy but its ALOT CHEAPER then breaking the mold and re-molding them......Any reputable Performance shop in ur area should be able to do it no problem......Expect to see a price of labor around $500ish.   Thats why i just took a few days and did it myself
Euric, what's good man, how's the car club going.
Experience is something you get after you need it.
Chuck Norris Can Set Ants On Fire With An Magnifying Glass..........At Night
WitMyMoney wrote:Euric, what's good man, how's the car club going.
im good who is this anyway
if you do decide to go that route, you CAN do it with molded stuff.  Just take out the bolts, loosen the side etc, if it is molded to the door sil then it sucks, but if not you could peal up that tape if thats what holds it down, then just have someone help hold the fender back a little while u take stuff off.
http://www.aplusperformance.com
http://www.modified-motorsports.com
Or you can remove the door and unbolt everything while keeping the fender and sides on the car... it just take three times as long getting everything lined up and adjusted! Plus if you go that route then you will need a couple of extra hands cause the door weights a  ton!
