How do you paint the black plastic piece inside of thes lights? I've seen it done before but havn't found any directions of how to do this wihthout having leakage later on.
1. Find the button that says Search
2. Type in 03 clear or 2003 clear or clear healights
Find a result and click it.
Honestly you did not search because its ALL OVER and been reposted tons of times.
Make sure you put enough silicone back on when you reassemble and you dont have a problem
http://www.aplusperformance.com
http://www.modified-motorsports.com
ah your right i did not search, I know I should've but I figured that people woudl be courteous enough to be able to point me in the right direction. Thank you.
I was not able to find them through serach, do you have a direct link?
You didn't search good enough
I don't think that theres one for actual painting, but once you get the sealent apart the insides are very easy to take out. After that just get some paint that matches you ride and work from there.
04 Cavy LS Sport
can i pick up some avril blue from any where or should i get it from a body shop. Preferably in spray can cause i would also like to do some interior paint as well.
YOU CAN ALSO SEARCH FOR MY HOW TO I DID sorry bout the caps LOL
search for 04 clear corners it was a quick how to  but it pretty much coverd it all
