is the gas door on a cavy just held on by the little rod ? if yes how come mine wont budge ? could it just be seized ?
there should be a couple rivets holding the hinge onto the car.  it would be easier to drill those out than it would be to try and get the hinge rod out.
hmmmm i just need to change the door  with the custom one i am making, i dont have the hinge assembly from the other one !
sunstealth wrote:hmmmm i just need to change the door  with the custom one i am making, i dont have the hinge assembly from the other one !
How custom can a gas door be?
<img src="http://thespork.dataride.com/theorg/sig.jpg">
Visit The Spork
on mine there were a couple bolts that went through the 1/4 and were held on by a couple nuts on the backside (7mm or 10mm, not sure what...)
held on by 2 9mm nuts on the back side in the fender well
<img src=http://registry.gmenthusiast.com/images/brandonfetter/fettersig.jpg>
i removed mine, have fun, u have to drill the rivits out, and twist and pull that off. wasnt fun
JJ
i am making a toyta cavalier style gas cap with no "hump" in it it will be all flat when done
brandon fetter wrote:held on by 2 9mm nuts on the back side in the fender well
yup...only im pretty sure they are 7-8mm
<img src="http://registry.gmenthusiast.com/images/tabasco/JBO%20ad%20banner%20brown.jpg">
www.TabascoRacing.com
Everything else on a cavy is 7mm, so thats prolly what it its, i dont think i've ever used a 9mm on my car.  Not saying your wrong since i have no idea what it is, im just saying ive never seen a 9mm, mostly 7 and 10.... But this IS GM were talking about so theres no telling.
