Yes i searched, no i didnt get the answers i wanted lol,  Ok so i can take the sunfires front fenders,hood,headlights and swap them onto my car no issues correct? i'm thinkin a nice 03 front end would be good since i love the new body kits anyway, now my questions are.... the headlights, how much of the wiring needs to be changed? I have a 98 so its still a 2 bulb headlight,  should i just buy aftermarket parts, such as front bumper and hood? will this cause a problem fitting everything or will these parts literally drop right in?  thanks in advance.
J~
if you have a 98 cav, then the 03 fire lights will NOT need the different harness because they both use a two bulb system.
and the fronts of the cars, 95-05 all bolt directly up.  its cheaper to swap, but looks better if its all aftermarket IMO.
if you need any more info, IM or email me
 <br>
<img src="http://www.tabascoracing.com/images/splash_01.jpg"><a href="http://www.tabascoracing.com">
There will be no problems fitting everything unless your car has been in an accident. I did that exact swap as you can see in my sig with all aftermarket parts (besides for the hood.) You can use the fenders from any year sunfire. I just spliced in the headlight bulbs. They take H9 and H11 bulbs but with little modifications to the housings I got it to accept 9006 and 9007.  Just get the right bulbs though.... It will all "drop right in." E-mail me if you have any more questions. <br>
Cardomain|
Myspace
ok so if i use the 95-99 headlights are they a single bulb system?  if so what parts do i need to convert to make it work out right, i found a great deal on a pair of 99 headlights and some other pics have swayed my opinons
 so i decided to bring this one back up and get some more answers, thanks in advance.
J~
J~ wrote:ok so if i use the 95-99 headlights are they a single bulb system?  if so what parts do i need to convert to make it work out right, i found a great deal on a pair of 99 headlights and some other pics have swayed my opinons
J~
95-99 cav headlights use a two bulb setup.  so does a 03+ sunfire.  you shouldn't have to change any of the wiring.  if you want to convert to a 95-02 sunfire front end, you're gonna have to change your wiring since they use a single bulb setup.
^^^^ what they said i did the swap on but the cavt front end on it.  If you have the money like i did i would go aftermarket here is a pic of mine.
Norms Fenders
Holes in front bumper from plate bracket (custom)
Solo Hi Flow Cat/ 3in dual exhaust
Kappa Intake/IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
Dakota Digital EGT & Boost Gauage
DDM Probeam
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
AlkaControl Water/Meth Injection
i'm trying to get a set of stock fenders, an aftermarket bumper, and if i can find one decent a factory hood since i'm not a huge fan of fiberglass parts, steels easy to mod to
, does anyone happen to know if i can simply swap a harness out for the factory headlight? and if so what part number am i lookin for?  thanks in advance again.
J~
someone help me out here too? Ive searched and eeverything, too many confusing posts........  I have a 95 sunfire and im swapping to cavalier front end......  what do i need for wiring? thats all i need to know......  please
