HI there i have the buddy club rear, blitz front type obx sides and all fit great except the rear.  i had to sand lots of the bumper to get it to bolted up properly. problem is now there is a gap between the rear bumper and the trunk, im talkin like a 3/4 gap. anyway it looks sick, how do i fix this.
is there a gap because you sanded too much off?
is it fiberglass?
where did you get it?
is it a gap or is it sagging?
yah i had to sand a @!#$ load to make it bolt up.  i got it from soundspeedsports.  yes its fiberglas.  its sanded fairly straight and there is a lot of gapos in some spots
nothing that a body shop cant fix by just adding more fiberglass to it...check around your local shops and ask them
I had the exact same problem with mine, It doesn't fit, I only test fitted it but it was so bad that I know it will not fit...He said that he can fit perfect in 40 minutes but I am not sure on that.....
UNDER CONSTRUCTION!!!
Check out my site
http://members.cardomain.com/lil_z
yah i no i phone and i was a little pissed, but they were great, so now i guess down to the body shop i will go
if it just sags under the trunk lid.  no need to pay for a body shop to fix it.  head to home depot and get some L brackets.  mount them to the bumper support and then when you put the rear back on, rest the middle of the bumper on the brackets.
