Can someone measure the distance from the top of the trunk to the part that the wing sits on the trunk? Here is a quick drawing of what measurment I need. Thanks
LowFire wrote:LOL
Best drawing evar!
Ha Ha,
  I couldn't figure out what that was, luckly it's labelled
9.5 inches
<img src="http://www.j-body.org/registry/amarkham/bomexcavi6sig.jpg">
yeap   he is right i just went out and measured...its 9.5 inches
Thanks to the last two guys, for the first two all I have to say is "no comment".
It mounts in the stock holes, if that helps any.  You could have someone you know remove their stick spoiler and get all the hole measurements.
well actually the thing is that I mounted the rksport cf adjustable wing on my trunk. I like it and it looks alright but I think a prostock cf one would look better. So I want to see if the prostock wing would cover up the holes that I made for the adjustable one. I'll have to check tommorow, im too lazy to go outside now. Thanks again guys.
James (ROLN19S) (JuicyJ) wrote:It mounts in the stock holes, if that helps any.  You could have someone you know remove their stick spoiler and get all the hole measurements.
rksport sends tabs to help drill the holes with...theres no need to measure anything
