Ok so I got a shop to mold my side skirts and they molded it to the bottom on the front fender as well. To install the lambo doors you must take of that fender right? So I am gonna have to cut it from the side skirt to do the install right? Just want to make sure. Thanx guys
if you have to remove it you will have to cut the molded part off there is no way to get it off without doin it i dont know about the doors though there might be a way to install without removing the fender hope i helped
<img src="http://registry.gmenthusiast.com/images/zjoneshybrid/personal_pic.jpg">
Ya I just need to know that you must remove the fender to install them.
is the back of your kit molded in?
what do you mean the back of the kit?
ive heard it is very hard! i plan on moulding my side skirts but im going to leave the front of the skirt unmolded.
@!#$ it I'll probably just smash the molded part I got some other body work I wanna do too... Not really likin my hood scoops anymore.
Its a pain in the @!#$ing @ss.  Took me like 4 hours to do my one hinge.  But I had to bolt in a metal plate that my shock attaches to, most kits just have the shock bolting to the stationary hinge part.  And there is no way a drill will fit behind the fender.
sorry about that stupid question. what i ment was is the back of the side skirt molded to the back quater. because if it wasnt you could have takin the side skirt and fender both off at the same time. just be carfull not to crack it. but it looks like ur molded in the back too so this prob wont help you any.
hah that's alright. Now that you elaborated I get what you were sayin. Like I said....SMASHY SMASHY
 nothing you can't fix later
streaker, howd the midas thing work out?
           Just STFU about the spoiler already......lol
Ill be molding my sides on, but theres a trick
Move the slit striaight up and down with the fender line, ill post when i go everyth ing iim still collecting a few more parts and been putting 18 hrs a day into the truck(just got home at 4:30am)
shower sleep gnight
If your skirt is molded its possible to do.
It is difficult but it can be done.  You just have to remove the fender bolts, then be able to kinda move the fender back soyou can get inside, the stock fenders have alot of give to them so I kno when I adjust all I have to do is remove the 4 bolts on the top of the fender, and kinda bend it outwards a little bit.  It will take some time, but could be done
We did it just like Z2flip4 did.  It takes a long time but you will avoid cutting the mold.  Good luck
<img src="http://registry.gmenthusiast.com/images/imp0rtfighter/personal_pic.jpg">
* PROJECT QUEEN Z SET TO DEBUT ?????? 2005 *
* MY CARDOMAIN PAGE *
