I wuz contemplating some ideaz bout my doorz and i wuz thinking since everybody and there mother's grandmother has lambo doorz i figured i would go down another route w/ tha suicidez. Now how hard (and how expensive) iz it 2 install just tha two front doorz on my 03 sedan. cuz I think it would be sweet 2 have tha front and rear doorz open up 2 each other!!!!
itz not what u drive, itz what drivez u
Probably something a professional would have to do, you have to create new hinges, and if they are mounted just slightly off (talking millimeters), the door won't close and seal. Not something that is impossible to do my all means, but also not something you want to attempt if you've never had experience in that area before. Hanging a door on the stock hinges is hard enough
 cuz i just got tha idea playing Need for Speed 2.  but I hear you about tha stock hinges!!!
in order to install suicide hinges on a sedan's front doors, the B Pillar needs to be severely reinforced and a custom hinge needs to be made.  it probably won't look very pretty from the inside cause there won't really be any room to hide the hinge.
on a side note, please type properly.  it helps people read your message better and makes you look a little better.
Musta forgot where the S key is...............
Prob look like sh;t since there is nowhere to weld in the hinge pockets cuz the pillar is so narrow.
Im sure Cannon's good buddy BigDaddy will be in here to tell us how to do it with stock hinges...........ahahhahahha
@!#$ you !!!!
can i haz bondo
i refuse to get involved in another discussion about anything any more
can i haz bondo
